Duragloss 105 with or without 601?
lkotsios
Does 601 mixed with duragloss 105 at 4 to 1 ratio improve looks or just adds durability?
It will improve looks if the paint is dirty and you don't use DG 501 to deep clean. It also extends durability, how long I don't know?
It does nothing for looks. The 601 helps the product adhere better to the surface thereby extending the durability of it. It also helps in that if you want to layer another product on it, you don't have to wait 12 hours for the sealant to cure and can do it right away. Richard's answer was good, I just wanted to expand on it a bit.
If i want to top off the 601 and 105 combo with 111 should i mix in 601 with 111 again or just use the 111 alone?
This is the reply from Duragloss:
Thank you for your inquiry. #111 does work well alone. By using 601, it adds durability and will help your polish job last longer. You can mix 601 with any of our polishes to save a step. Mix 1 part 601 to 4 parts polish. Mix when you are ready to use and only what you will need.
Thanks and God Bless,
Jerry, Technical Support
By mixing 601 with the 111, you will increase the durability of that final stage as well. Post up pics (and send me the link if you don't mind via PM so I don't miss it).
This is the first time I read about topping 105/601 with 111. The common combo is 105/601 or 111/601 over 501/601.
