Folks,
After TONS of research I have decided to go with the Duragloss line. I've ordered the 501, 601 and 105. I was going in this order:
Wash/Dry
Clay
501/remove
601/leave on, followed immediately with 105
Remove both
Optionally followed by Souveran (not sure I'll do this)
I read somewhere on this forum that once you remove the 501, go around the car with the 601, but leave it on and put the 105 directly on top of it - removing them together. Is that correct? Sounded like the 601 was a booster to the 105's durability.
Also, what kind of cure time should I do if I decide to add the Souveran?
Thanks in advance.... so much good info. on this forum!!!!!!
Wash/Dry
Clay
501/remove
Remove both
