- Thread starter
- #21
I tried Ech2o today. I thought it worked great. I made a QD with a ratio of 1:20 and rinseless wash at 2oz per 3 gallons. I wanted to use it at the lower ratio vs the 3oz per 3gallons. The sun was at the right angle where I could see if there was any streaking, so I wanted to try it then. I pretreated the surface with the rinseless was ratio in a spray bottle, then wiped it down. Surface feels very slick after using this. I followed up with the QD and that also worked great. I tried it on the interior and it worked well at the QD ratio. Will use the rinseless ratio going forward for pretty much everything. That faint haze flashed off quickly and it was very easy to wipe down with no streaking.
I like how slick this stuff feels, unless the Can Coat is adding to that? Either way, no streaking at all and surface felt super slick afterward. I'll likely use this going forward for interior and engine bay too.
