Entry level Electric PW-thoughts, advice etc...
I've heard good things about the one from Sam's club. I think it's black max? That's what I will be getting in the next month or two
Sent from my HTC6500LVW using Tapatalk
i've said this many times.. if i were in the market for an electric pressure washer (did quite a bit of research), i would get the blackmax 1700psi pressure washer from sams club. it's right under $130 or so and comes with a 2 year warranty. it's gotten good reviews across the board and it's essentially the same one from ryobi (also has gotten favorable reviews as well) just re-branded...
Along the same lines as the Sam's Club unit, I bought the Simpson at Costco. Can't beat a lifetime satisfaction guarantee; if it ever fails, I bring it back for a full refund.
I picked up a Ryobi electric PW from Home Depot. $165 or so and it has a 3 year warranty! Used it about a dozen times so far and love it! Also it's only 1700psi but works perfectly with my foam cannon and it's not too strong that if you catch the paint by accident, it won't strip it or anything. Definitely look into it.
Get a used gas pw from the home Depot, they're usually less than $200. ( returns). My local HD has a few all the time. Way better than electric imo.
Ha thanks!
I was looking last night I had decided on the ryobi from HD it is $150 with 3 nozzles and 3 year warranty.
I have zero desire for a gas one.
Sent from my SAMSUNG-SGH-I747 using AG Online
for the guys with the ryobi..how do you like it?...i've been looking at that one as well...i'm torn right now cause i have a 2300 psi 2.0 gpm gas but the pump went bad....new pump is 190$. now the ryobi is only 159....but not nearly as much cleaning power...just wanted some input as if i should repair what i have, or go for the ryobi...or one of the like.... just need it to work with my MTM next gen foam cannon without having to buy to many extra parts..
I personally hate gas ones. So you could always try it then return it if it isn't up to your standards. But less maintenance still cleans the car fantastic give it a shot.
I purchased the smallest PW that was available at Wal-Mart last year.
It's their own brand (Tune it!) and it was on special for 48 CAN$.
The unit is 1600 PSI, which is plenty for what we do. It's hand held, weights about 5 pounds so it's very easy to carry around.
I came with an adjustable spray nozzle and a foam bottle.
The only issue I have is that I would like the hose to be a little longer, but since the unit is lightweight it's not so bad, just move the unit.
What I like about this unit besides the ridiculously low price is that being so small it's great for mobile detailling.
I love mine. Easy to use and transport, removable handle for fitting it in my trunk. It also is exposed so there's no stupid plastic cover to break and it's got a nice metal frame. I bought a std. PW attachment for my MTM cannon and it worked perfectly. This was the first foaming I did on my 335 with the Ryobi PW, MTM cannon and honeydew.
Untitled by c.merritt, on Flickr
I've never been satisfied with electric. The pressure and particularly the GPM is far to low for anything useful, IMO. One area where an electric is probably fine is a foam canon.
Which for someone like me who uses it only for the foam cannon and wheel wells it's perfect!
My dad has a big gas one with like 6000psi or something but can't use that for detailing
I had a karcher that lasted well over 10 years,just bought another karcher 1600,works fine for my cars. I also have a gas Troy Built that I use for everything else. I only feel comfortable using a elect PW on my cars just because it's not as powerful,and I'm afraid the gas one would wash the paint off! LOL
Perfect for stripping LSP, Clearcoat, Basecoat and primer. Now that's what you call a naked surface ;)
