No need to wash with dawn. You can use IPA mixed at 70% and have no issues.
With EXO work in small sections and remove quickly. If you let it sit up to long you will be left with streaks and have to polish to remove them. The small the sections you work in the easier the coating is to work with.
If your planning on two coats of EXO which I recommend then wait 3 hours before applying the second coat.
Question: i applied the C1 and EXO combo last August 2014. It still looks great.
I had a difficult time with EXO flashing quickly and leaving streaks.
Has EXO been improved so it will not flash quickly?
I would give it another chance if it were easier to work with.
If you are having issues with streaking then you can either do one of two things:
1. Shrink down the area you are working on.
2. Apply and wipe off.
Heat and humidity play a huge factor in how quickly coatings flash. The higher both of those are the faster it will flash.
Its much easier to transfer exo into a small spray bottle. One spray, than microfiber in other hand and wipe it off, I found this method working the best, no streaks, and VERY easy to apply. They should include a small spray bottle with exo, or have it COME in one.
Yes that was the old version too, and a lot of people liked it that way, not sure whey they switched, but using your hand to wipe this on typically leaves finger swipe marks and such when the product flashes, I found that using a small push spray bottle for .60 cents works AMAZING, even coats, and no streaks what so ever, even on black cars.
Are you saying to spray Exo on the panel and wipe to spread OR spray it on the microfiber and apply? I have Exo in the aerosol can.Its much easier to transfer exo into a small spray bottle. One spray, than microfiber in other hand and wipe it off, I found this method working the best, no streaks, and VERY easy to apply. They should include a small spray bottle with exo, or have it COME in one.
