BadgerRivFan
Member
- Aug 28, 2015
- 886
- 5
WETS is what I recommend. Yes, it's a bit pricey, but a little goes a long way. I usually use a small cheap MF Rag cut up into 2"x2" Squares. One square will last weeks and once wet with product will go forever. Literally 1-2 drops once primed will do quite a bit.
The B-Pillars on this one were starting to "grey" out. Took a few applications and weeks but eventually the "like new" look stayed and now it doesn't require a reapplication for several weeks or months. Notice the window trim along the bottom of the window where it meets the door. Those are rubber and look new too.
Plastic Grill.....like new: Doesn't soak up a lot like other materials so I retreat this every month or so.
Cowling along windshield was faded to gray. I restored it using ReNu Pro. Once restored, a little WETS keeps it black and beading like brand new. Same with the wiper arms. They now stay black and don't fade or turn any more.
I used the same ReNu Pro on the grill and it too looks new and is simply treated with WETS every couple months.
The toughest peice for me was the rear step cover. It was gray/white with sun damage. Restored with ReNu Pro and treated with WETS monthly. It took 2 treatments of ReNu Pro but it now looks brand new and stays. Here it is beading water from a rain storm.
Just have to say this is an exceptional post pdqgp! Great contribution to the topic!!
Also have to jump on the WETS bandwagon... easily the best exterior trim sealant. Dlux also gets high praise but as it is a coating takes a little more care in applying.
