Extractor Spraying Tip or Nozzle
Beavis
Does anyone know where to buy some extractor tips. I have a mytee II lite and the tip ojly seems to spray about the width of 1in when you know the vacuum is what 4in. Sure makes for alot of extra passes. If anyone know where I can get some different tips (or maybe called spray nozzle) it sure would help.
Thanks
Shawn
powr-flite i have a thermax but they have parts for all the tips and nozzles are pretty much interchangeable
Thanks for the quick response.. yeah I checked it the other day and it was clean. it has always sprayed like this and someone told me you can get different tips for it.. Does yours have a wipe spray pattern on it and if so are they certain kinds of tip that have a bigger pattern?
Local: any janitorial supply house or reseller.
Web: Google carpet extractor spray nozzles (tips).
I am a pack rat. Even after replacing tips, I save the old ones and clean them up with emery cloth. Some times opening up the brass aperature with a razon knife in a vise.
Down side is that you can break off and trap a corner of the blade in the opening, leaving you in worse shape than you started.
