Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Extreme Floor Mat Makeover - How to machine scrub floor mats to remove stains
Recently traded the Golden Eagle in for an INFINITI QX30.
Review: PBL Paint Coating & Surface Coating - 2017 IFINITI QX30 - Magnetic Red
My wife Stacy is a tick on the OCD side about an immaculately detailed interior. Me? Not so much.
To protect the factory carpet mats she ordered the factory rubber mats. When they arrived they were HORRIBLY stained with some kind of white stuff on them. We called the Fort Meyers dealership, (the nearest dealership that had them in stock), and shared a picture of the appearance of the mats brand new out of the packaging and the kind IFINITI parts department staff immediately said he would send is a replacement set AND would personally inspect the new replacement set to make sure they looked right. Called us back and said all the QX30 mats had this white staining defect.
Bummer man. :dunno:
So, the detailer inside of me took this on as a make-or-break situation because Stacy wanted factory mats.
Here's how they looked from the dealership.
See it?
And whatever it is, a little spit and my finger doesn't rub it off.
The best way I can explain it is whatever "it" is - it's stained-INTO and impact ONTO the rubber.
Not pretty....
Spray spray spray...
Machine scrub scrub scrub....
Note how I go up on edge to get the bristles INTO the sub-surface channels?
I also worked a brush into the tight areas really well...
No pictures
Sorry, no pictures of the,
After Stacy did the drying and dressing aspect I then air-blasted each mat using the Tornador Black Air Blow Out Gun.
BOOM!
Now they look right and the look tight!
Here's most of what we used... the Carrand brush for for hand scrubbing and the Horse Hair brush was for working the Multi-Surface Dressing
The BLACKFIRE Multi-Surfaced Dressing Concentrate is WATER BASED. Here I've poured some of the concentrate into a measuring cup of water and then mixed it up to show it stays in emulsion. Another way of saying that is it does NOT separate out.
So much less slippery or slick than a solvent or oil based dressing.
The mats came out great. Not perfect but we can live with them. They look GREAT in the car and the carpet mats are protected.
Warning: Use a vinyl/rubber dressing on floor mats at your own risk. The cleaning process removed about 97 percent of the white staining appearance and the dressing tool the results over the top. My thoughts are moving into the future, secondary and thirdary cleaning will completely fix the staining issues.
On Autogeek.com
BLACKFIRE Mat Cleaner & Protectant 32 oz.
BLACKFIRE Multi-Surface Dressing Concentrate 32 oz
Carrand Deluxe Interior Brush
Natural Horse Hair Interior Upholstery Brush
FLEX PE-150 Cordless Rotary Polisher
Heavy-Duty DA Carpet Brush – Long Bristles
Rotary 4 ¾ inch Flexible Backing Plate
Cobra Supreme 530 Microfiber Towel, 16 x 16 inches
Bummer man. :dunno:
See it?
Not pretty....
No pictures
- Rinsing clean.
- Blow drying with a MetroVac Sidekick.
- Applying BLACKFIRE Multi-Surface Dressing and working in with Horse Hair Brush.
- Wiping excess off and out of channel areas with Cobra 530 Microfiber Towel - the fluffy side.
BOOM!
On Autogeek.com
