Favorite AIO/polish for easy hand application?
skyavonee
I'm seeking out a new 2-step process to maintain my car's paint. The car is a black Miata; it's my daily driver, and I park in a dusty carport. I won't bother investing in a DA until I have a clean, well-lit garage to work in. In the meantime, I'm looking for products that are easy to use by hand.
I'm already sold on BFWD for my 2nd step. For the 1st step, I'm looking for an AIO or polish that will clean the paint and reduce swirl marks.
What is your favorite product for my situation, and which applicator do you recommend?
BFTPS is an obvious option, but its directions leave me wondering if there are better alternatives for hand application.
An AIO will have protection in it. The BFWD may affect it since it's solvent based may cause failure of the protection from the AIO which are usually polymer based.
I know Autoglym SRP will not be affected by a solvent based sealant since it's resin based instead of a polymer and the Autoglym topper they make for the SRP is solvent based.
It's a good AIO for hand application but it does flash fast so you will need to work in small areas to be able to work the polish. I would suggest a Orange LC foam hand applicator on softer paints.
My other AIO that I love that might work for you even though I never used it by hand is Menzerna FAJ. ( It is not in there current line up but you can still buy it online. It has really good cut for a AIO.
Look into Prime Strong AIO it has good cutting ability. You will need to check and see if it can be applied by hand. I plan on picking it up when my FAJ runs out.
The other option is to go with a paintwork cleanser then the BFWD over the top. A really user friendly cleanser is P21s. It's a little pricey considering the size of the bottle you get but a little goes a long way, however you always end up using more product when you are working by hand. It's easy to use by hand and gives great results. It would not be affected by any sealant or wax you use.
Any of these Meguiar's AIOs:
-A12 Cleaner Wax
-G61 White Wax
-G62 Black Wax
IDK? I have used BF TP&S by hand before. As a 1-step. Turned out great. No issues. It is a unique product. As it dissappears into the paint.
You'll probably have minimal luck getting swirls out by hand with an AIO, but there are some good ones at filling in swirls. Bob's recommendation of Meguiars cleaner wax is a good one for that. I personally like Klasse AIO as it's pretty easy to remove and the white residue that most all AIO products leave behind seems to be easier to work out of the nooks and crannies with Klasse than some others I've tried.
KAIO leaves minimal protection behind, and was designed to be topped with Klasse HGSG. So if you add a sealant to the top of it, it's not bonding a sealant to an undercoat of wax as it may in a cleaner wax scenario.
I wouldn't bother with an AIO if you're topping it with a sealant. Go with a glaze that fills and plays well with sealants like poorboys black hole or prima amigo.
Trying to use a polish of any kind by hand is futile especially on black.
As for polish/glaze, Prima amigo provided great results for me by hand. Then i followed with prima hydro max.
I'm starting to think I'll go this route. I can do a glaze + sealant every 4-6 months myself, and then just pay a professional to do a clay + polish every 12-18 months.
I'm seeking out a new 2-step process to maintain my car's paint. The car is a black Miata; it's my daily driver, and I park in a dusty carport. I won't bother investing in a DA until I have a clean, well-lit garage to work in. In the meantime, I'm looking for products that are easy to use by hand. I'm already sold on BFWD for my 2nd step. For the 1st step, I'm looking for an AIO or polish that will clean the paint and reduce swirl marks. What is your favorite product for my situation, and which applicator do you recommend? BFTPS is an obvious option, but its directions leave me wondering if there are better alternatives for hand application.
Do not use these products with a machine. By hand only.
#1. Swissvax Cleaner Fluid Regular. Not a particularly user friendly product but definitely the best. I use it exclusively for delicate paints and to prep paint for wax. $165 per liter.
#2. Auto Finesse Tripple. The best AIO I've used in very long time. The protection part of the AIO is weak though, definitely follow up with wax of your choice. $20 per 16 oz. Just a killer value.
you can try HD Speed. Hand friendly, correction (though by hand its notgonna show much) seal and shine. its great stuff also.
^ from what i gather, hd speed is a combination of both hd polish and poxy (don't know the percentage of each). which are both great products...
I've always liked Meguiars ColorX, topped with NXT, or TW Ice Paste. Like Bob said, most of these cleaner waxes by Meguiars are great. The White Wax is another one I like.
I agree. CFR is awesome. And, I'm not a Swissvax fanboy either. The few other products I've tried from them seem overpriced and nothing great (except the leather brush). However, CFR is a great pre-wax cleaner that fills and leaves a super glossy surface. I had no issues using it. I wouldn't recommend it with a sealant though.
I'm not sure about "correction", but a Prima Amigo is quite good as well. I don't think correcting a car by hand is realistic (although I'm sure possible) - so my main goal would be filling. Amigo does this, cleans the paint, and leaves a glaze behind as well. Super user friendly to use. It's better than BF GEP and will work perfectly with BFWD.
If you are using BFWD as your sealant, I would go with TPnS for an AIO. by hand, use a white foam hand applicator. You don't need much and work it in until it nearly disappears. No cure time, so you can go straight to the WD after you finish with TPnS.
Auto Finesse is very easy to apply by hand or by DA. Here is picture of it applied by hand.
Thanks again everyone for the input. I think this time around for my simple two-step process I'll try Poorboy's Black Hole Show Glaze and Poorboy's EX Sealant with Carnauba.
In the future, I'll probably try Auto Finesse Triple, Prima Amigo, or one of Meg's products as my first step, followed by BFWD or similar.
