Finally got a pressure washer...
DeansDetailing
So, I did about 20 vehicles with the foam gun. while that works well in most cases there are situations where I could have used a pressure washer. Wheels/Tires/Wheel Wells and some truly dirt packed wheel wells and paint from off roading...all will be easier with the pressure washer. Just ordered it:
Sun Joe SPX3000
2 of Bosch Garden and Watering Green Thumb 7FHS7FGT Hose to Hose Connector
Camco 20143 Quick Hose Connector with Flow-Through Connection
Apache 10085585 1/4" x 50' 3100 PSI Xtreme Flex Pressure Washer Hose with Female Metric Fittings
If you're gonna be in this for the long haul,Honda is a suggestion never any promblems at all,but you do what you can afford right now just a suggestion later Down the road.
Oh, yeah...I feel ya. This seems like a good entry level solution until I can upgrade all my gear. Will probably use the above model for mobile and get a gas powered unit for the shop in the not too distant future.
I went by the SunJoe longer hose thread so hopefully everything works out.
