PouncingPanzer
- May 11, 2017
- 1,101
- 331
- Thread starter
- #41
Consider standing where you are with the G9, the Perfect Finish, maybe get some Yellow Buff and Shine Uro-Tec foam pads (similar to Rupes yellow), and pick up some Uro-Fiber for heavier cutting. A great compound to pair with it would be Sonax Cutmax or Ultimate Cut. I've seen a lot of detailer's get a lot of mileage from Perfect Finish though. From cut to finish it has a lot of versatility. An unsung hero of the Sonax line is Cut & Finish. So much cut, and such a great finish. It's a true medium polish if you ever saw one. An AIO from Sonax I believe is called "paint cleaner". Not 100% on that one though.
For an AIO I really like 3D Speed. Works great on the yellow pads as well.
Hex Logic is manufactured by Buff and Shine. Great quality components and construction.
Someone mentioned the Rupes offerings. That's not a bad suggestion either. They have everything set up for you, and the polishes are extremely high performing. The cut and finish from the Coarse has been just tearing it up at the shop for me. I finally dialed in a process that eliminates a lot of the dusting issues, and the time saved is remarkable. Their DA Fine, can cut a bit, and finish a lot! The Uno Pure... It's so fine that on some paints it won't make a difference. I haven't tried the Uno Protect yet, because the shop where I work is almost always doing coatings. One of the guys that works there used it on a job we did together and it worked great. Seems to cut more than 3D Speed, and finish just as well. But - that's not to say you should go that route, just that in the future, once the Sonax and LC pads wear out, you might want to consider it.
Thanks for this! So much knowledge I'll take what I can get :xyxthumbs:
