AeroCleanse
- Nov 17, 2008
- 2,422
I use Iron Cut from Aquartz, but AG doesn't carry it (yet I hope)
OK. I used the Finish Kare Paint Decontamination system yesterday. The victim was a new white 2010 Kia Forte Sedan. It had massive protective film adhesive residue, rail dust, all kinds of paint contamination. I started with step one, it is a white liquid, mix it 4:1, I found that adding the 64 oz bottle to 2 gallons of water worked best. It has a mild solvent smell, best used outside. You sponge it on and let it dwell for 5 or so minutes. Being careful not to let it dry. Looking at the rinse water coming off, you'd think the car was black. Next up, step 2. It is a yellow'ish liquid and obviously acid-based. USE GLOVES! This is applied full strength to a couple panels at a time, again... DOT NOT LET IT DRY. It did require some agitation in a few spots where the rail dust was concentrated, but you could actually see the little orange spots slowly disappear. Let this dwell for 5 or so minutes. Then, wash with step 3. It is supposed to neutralize step 2 and remove any additional grease, wax or whatever. For those of you who are worried about plastic and rubber trim... Don't. It had NO effects AT ALL on any of my trim, even chrome plated plastic.
Does this replace claying.... NO. Does it significantly reduce the time spent claying... YES. I took an additional 30 minutes or so spot-claying some difficult areas.
Overall... definitely worth it. The paint was smooth as glass on 90% of the paint surface after the 3-step system alone.
Anybody have any ?'s on anything I missed.... lemme know.
EDIT: I think that Meguiar's body solvent would do the same as step one, but at a greater value.
I believe it was Accumulator over at Autopia who said that he would often clay while the Step 2 of the Valuguard was dwelling. He said it was like claying on steriods. A highly contaminated that would take you a few hours to clay would become a very simple task. The bonded contaminants would come off so easily.
I own and have used the Finish Kare Decontamination system several times. It does indeed work. :xyxthumbs:
Do bear in mind that step two of the Valugard system is the alkaline product, while step two of the Finish Kare system is the acidic product. If using the Finish Kare system, you'd want to clay during step one. I would think though, since step one contains petroleum distillates, it would eat up your clay pretty fast.
so for you that have used it, are you mixing step one in a bucket or spray bottle? and how about step 2? dump the bottle in a bucket or just a spray bottle? very interested as i just acquired an 06 chevy trailblazer, white in color, with obvious brake dust, just want to make sure im clear on how to use it so i dont waste 40 bucks. thanks a million.
