Spiney
- Aug 19, 2011
- 449
DG 101, DG 501 and to a lesser extent 105 are all an AIO, so they will clean the paint, lightly polish and leave a DG sealant on the paint. You can follow up with DG 111 which is a finishing sealant. For longer durability and quicker cure times, you can mix each with DG 601. 4 parts of any of the 501, 101, 105 or 111 with 1 part 601, and you are good to go.
If you were to go this route, which of the Sealants would you use? I will be buying and mixing with the DG 601 and when I get the time probably topping off with Collonite Wax. I'll be applying the Sealant with a Griot's GG6. What pad and speed should I apply the sealant with? Thanks.
