I can feel them with your fingers not your nails.
Nasty! What's on them?
It's interesting you started with such an aggressive cut. I use uni grit Velcro backed pads (3"): start with wet 1000 grit then move to wet 3000 grit on a Meguires Velcro hand grip. Then polish off with Menzerna compound. IPA the lens then apply OptiLens. Looks great and takes more than 25-30min start to finish.
I think sometimes folks feel the need to take off too much material from the lens. I like to take as little as possible to regain to original look and clarity.
Bbg18t 1000 grit will not make a dent in flak seals that I have removed. The use car lots that I clean headlights for get some realy bad lights.
Thanks for the info, I'm sure as I fine tune my skills it will take less time. I'll try the IPA after the compound step next time.
Most head lights I do come back to 90% + using heavy grit and going up have not had to buy a set of head lights because of sanding. It does take some time but I like to do a good job and I hate it if it is inside the lense.I've used as low as 400 paper on really bad lights. 400-1000-1500-2000-3000 then compound, Polish, coat. Sometimes it's overkill, but they always come out awesome.
How long sanding with 1000 grit when the UV seal is coming off.^^I would NEVER use a 200 or 600 on headlights..lowest ever is 1000. Most stuff comes out with a 2000 followed by 3000, finished with a polish.
