First Post
oldJames
Hi Mike,
I am new to detailing and want to learn how to maintain my families vehicles. I have read a number of articles which I think give me a basic knowledge.
I have heard that adding a little rinseless wash, especially one without wax or gloss enhancers, to the Rinse Bucket of a normal two-bucket method can help pull dirt from the wash media.
Do you have any thoughts or ideas if this would be an effective technique?
Thanks
Hi Mike,
Thanks
I haven't heard that but it sounds interesting! I can't wait to hear a response!
Sent from my SM-G975U using Autogeekonline mobile app
Welcome to AGO, James. :)
While adding the rinseless to the 2nd (or "rinse" bucket) couldn't hurt, you will be safer with multiple wash mitts.
After one mitt is used, it gets thrown in the "used" bucket and never touches the paint again. Instead, a fresh new mitt is pulled from the wash bucket, and so on.......
This way, any used mitt will never introduce any dirt into the wash bucket. :xyxthumbs:
Hi Mike,
Good for you and thank you for joining the forum. :dblthumb2:
Thanks
I've never heard of this?
I don't know of any rinseless wash that does not contain wax or gloss enhancers or shine agents?
I would bank on a chemical removing dirt from my wash mitt "enough" to then think this would be the way to avoid swirls and scratches while washing a car.
Here's what I do - use ONE BUCKET and lots of microfiber towels to wash the car instead of a wash mitt.
How to safely wash a ceramic coated car by Mike Phillips - Traditional Hose & Bucket Approach
It's real simple to figure out if you just take a moment to read the above article.
It's the TOWEL or MITT that is KEY to keeping your car scratch-free -Mike Phillips
I never use the 2-bucket method to wash a car. Haven't for years. I use 2 buckets, one for my microfiber towels for washing the car and a second bucket called the Wheel & Tire Brush Bucket to hold my wheel and tire brushes.
I think I share the practice of using a Wheel & Tire Bucket in video Number #7 here,
Complete List of Live Broadcast Videos on YouTube - Yancy Martinez & Mike Phillips
wow now that I coated my car...LOL now I have to have to maintain it...first what car wash should I use...can I use a wash mit...or have to use microfiber towels...also can i use ceramic coating spray ...need help
I am not sure that I am the one to answer your questions, but I would say that any car shampoo from one of the leading manufacturers would be a good choice. Yes, a wash mitt, and 2 buckets (wash and rinse) would be recommended (a third bucket for only cleaning wheels). Plush microfiber towels will help with drying. There are tons of videos, on manufacture's sights and on YouTube. Watch several and make a plan on how to proceed. Hope this helps
I've not heard that one. The only thing remotely similar I have heard is to add 1/2 oz of rinseless to your car wash solution to act as a water softener (ex. Uber Rinseless suggests this).
I tried this idea a bunch of years back thinking the same thing.
Knocks the hell out of your suds, giving you basically a RW when you want suds.
Any wash with out waxes or polymers should do. Forum favorites Reset (my fave) Optimum car wash and Meg’s hyperwash.
A mitt with a wash a rinse bucket is the two bucket method but many including myself use one bucket and alot of MF towels or wash mitts. I use 8. Use one mitt or MF on a panel and then use a new one. Old wash media never touches the next panel.
Most ceramic sealants can be used as a topper. A ceramic lite spray coating shouldn’t be used for maintenance but i used one after a year cuz i still had it.
Thanks for the information. Is a wash mitt better than a microfiber towel like 500 GSM? Is one wash mitt better than others?
Thanks for you input
Which is 'better' is not really the correct question, which one will not cause damage is a better way to view the options. I do ONR rinse less wash method and have used the 'Big Red Sponge' and never any issues. I also have and will continue to use the large chenille mitts for traditional wash (soap) as I think they release any trapped dirt or objects. I have the MF mitts and they hold lots of suds and very soft but I think they 'could' hold onto grit particles better so can be a hazard if not flushed clean. If you use a MF 500-gsm towel think of the length of the fibers. Often the 350-GSM have a shorter fibers so easier to rinse or less likely to grab and hold onto objects.
Mike in his videos uses a multi-towel method, (often the green Cobra towels, check out their Live videos) so they have minimal fiber length to not grab and hold onto objects. It really is a very solid method of using a one-bucket and reducing you chance of scratching the surface.
But if you have a dirty car with lots of grit on the surface, do a pre-rinse with your water hose or Pressure washer. In the end it is what is touching the paint that makes all the difference.
