David Puddy
- Aug 17, 2021
- 41
Hi all:
I've decided to try my hand at machine polishing on a recently acquired 2008 Toyota 4Runner (color is Galactic Gray Mica) and was hoping to get some feedback/recommendations on products and processes.
The truck has mild to moderate swirls throughout and some more noticeable scratches (but none deep enough to catch a finger nail) around the door handles and some fairly heavy scratches under the handles (I assume from finger nails, jewelry or keys). I'm planning to use a Griot's G9 DA with 5.5" Lake Country flat foam pads on a 5" backing plate (I bought 6 orange and 6 white to start) but haven't decided what polish and/or compound to use and with what pads. I'm not looking for show car results - I'd be happy with a 90% correction and restoring some gloss and depth to the paint.
Based on prior research, the 4Runner probably has fairly soft paint, so I was thinking of starting with Sonax Perfect Finish on a white pad. If the results were good I would stop there and proceed to a LSP. If swirls and scratches remained, I could try the Perfect Finish on the orange pads. Does that sound like an OK approach?
I also plan to wet sand the hood (it was repainted and has a bunch of dirt inclusions) and part of the roof (clear coat has some etching, probably from bird droppings). If I were to wet sand with 2000, 3000 and 5000 grit, would the DA/orange pad/Perfect Finish be enough to get the scratches out, or should I plan to start with a cutting compound? I don't mind buying a second product, as I suspect the scratches under the door handles will need something with more cut than the SPF. If I need a compound, would Cutmax work?
Thanks in advance for any insight.
Dave
Dave
