First time user of PC7424 & Klasse Sealant
ljdarby
Mayday, mayday...
Today I used my PC7424 for the first time, trying something "safe and easy" for my virginal trip. After cleaning my car carefully, full claying, I applied by hand a coat of Klasse Sealant. Problems:
1) probably applied too thick of a coat (no previous experience here) & let it dry as per directions;
2) tried to use PC 7424 for first time- used Lake Country wool pad covered with Lake Country microfiber bonnet at speed of 2, then 3, then 4 to remove haze left by Klasse Sealant;
3) haze removal went badly as MF bonnet would quit spinning even though wool pad on PC kept on spinning without bogging down, therefore removing the Klasse very poorly;
4) I "resolved" the problem by removing the Klasse Sealant by hand with MF towels, sometime having to spritz areas with detailing solution because of difficulty in removing said Klasse. All of haze eventually removed successfully.
5) My problems are these: do MF bonnets normally quit spinning when put over wool pads or do they bog down only when trying to remove excessively thick layers of sealant?
6) Your expertise and assistance would be greatly appreciated, so thanks in advance for any suggestions, help or feel-good therapy for this neophyte...
I always apply and remove sealant and paste wax by hand. I like Klasse AIO but I have never used Klasse Sealant. Most of the good sealants on the maket today come off very easy. It sounds like you left the sealant on to long or had it baking in sun. Next time you might want to try a product like Wolfgang Deep Gloss Paint Sealant or Poorboy's EX-P. Both products go on and come off extremely easy and look very good,.
I agree with Gary..the two sealants he has listed are very easy to work with..Klasse Sealant is a very finicky product...if you has some sealant left behind use a quick detailer to make it easier to remove
Thanks Gary & joe.p for your quick responses. I will consider your suggestions. BTW, the sealant was applied in garage, totally away from heat (it was 103 wind chill factor today in Louisiana), so these factors did not intervene to produce excessive hardening of the sealant.
Again, thanks for your suggestions to a newb like me...
QD, heck even water in a spray bottle. If your MF is moist it'll remove klasse a tad bit better.
