Ken,
My guess it it broke right at the handle.
The wire is very soft and bends too easily in my opinion thus the reason for it's short life. I suspect these are either insert molded during manufacturing or glued together as a secondary operation.
The wire needs to be flexible but should not yield or bend during use, this is a huge no-no!
Fixing this will either require drilling out the broken section of the handle or replacing the handle using wood or some other material, drilling it so the wire can be re-inserted and glued in place.
send it back and AG will replace it
I've had a few break on me and they replace them no questions asked
I've modified a broken one into a round brush for wheelwell lips, just bend around your closed fist and insert ends together with a piece of 5/16 fuel hose, put over your hand and make a fist, hose makes great handle and it works real well
