fixing scratched rims
before
this is the pics in order of process.
120 grit dry.
500 grit wet
1500 grit wet
3000 grit wet
this one has all the grits in order counter clockwise.
aluminum_compound put on with wore out 1500 grit disk
fine_aluminum_polish put on with wore out 3000 grit disk
aluminum_concours_polish put on with orange pad
concours_metal_sealant put on with white pad
in_polished_stage counter clockwise.
this is the original compared to the repaired rim
rim done
make sure to wipe rim clean between every step. this is my first try at a howto hope it will help out.
From what I can see in those thumbnails it looks like everything worked out well. Thanks for sharing with us.
thanks they did turn out good. some of the scratches were about 2 mills deep.if you want to see the bigger photos go into gallery here
They do look really nice. It's nice to see someone take the time to do such nice work. How many hours do you think you have in the project total?
go to the gallery here and do a search for rims my name will be on them
After your sanding, have you tried Jewelers rouge on a die grinder with a 4" firm cloth wheel...there are several different grades of rouge...after 3000 grit paper I'll start with #4 and finish with #6...seal it and it looks like chrome
