Setec Astronomy
- Aug 31, 2010
- 17,057
- 1,352
You need to work up in a progressive fashion. Try the toothpaste, if that doesn't get you the results you want, then go to an automotive polish. If that doesn't help, you may need to use a compound (like Meguiar's 105, for example). If that doesn't work, then you might have to sand. As you go more agressive, you may have to work backwards again (going finer and finer) to get back to the clear finish you want.
As I said before, they don't look bad in your picture, I'd stay with mild methods, particularly since this isn't your car.
