Flagged tipped brush & Duragloss #253
PA DETAILER
Well it hit 60 today. I was about out of the Griots satin shine aerosol dressing. So it was time to try a method that was pointed out to me here on the forum. I grabbed my new flagged tipped brush and #253 tire dressing that has proven to be perfect for me. Love the look and never slung off on to the paint. Sprayed the brush with #253 and applied it around the tire with the brush. Being I have aggressive tires now, other applicators are out of the question. Yes sir. I now love this method now that I have tried it! Works like a charm. Dressed the tire evenly and without drama. This is the method I will be using from now on.
Brush used...
Carrand Deluxe Super Soft Car Wash Brush, body brush, auto brush, car wash supplies
Thanks to Eldorado2k for pointing out this method.
It was supposed to rain today, so yesterday I looked at the tires on the truck and I wanted to dress them but I also knew that it might not be worth it because it was supposed to rain today. [It didn’t rain]
So I applied bearly enough dressing but nowhere near as much as I usually spray into the brush. It actually turned out pretty good and because I only applied a minimal amount there was really no need to wait for any excess to soak in. This picture is immediately after I dressed the tire with the brush.
I’ll probably continue priming the brush before applying, but this method of spraying less into the brush works as well.
I have that same brush laying around that I don't use anymore, I'm gonna try this method out next time.
Which brush did you use?
After detailing the wife's Pilot on Friday I was gonna apply a second coat of Silk shine to her tires yesterday but didn't because it was supposed to rain. I guess here in CA it's 50/50. The next time I decide to double coat the dressing it'll dump rain all day for sure.
The write up on that brush says it's ok for the body? Plastic molding maybe but I'd never used on the paint.
just bought that brush myself but haven't used it yet. I was thinking of using it for all the ground trim on my mustang. I actually bought it because of the handle. looks like it would be easy on the wrist. if I go with the wheel suggestion I'll need to dedicate it to the wheels. thanks for the tip.
I use this brush.
Yea I’d maybe use it on a matte honeycomb grill, but I don’t think I’d use it on paint unless it was wheels.
Brush worked out pretty good
I have to say that’s exactly how I like my tires to look. What dressing did you use?
I got it in a mystery bucket from chemical guys a couple of years back, this was my first time using it. I don't see it in the AG store.
I wash it maybe once per year. It doesn’t really get dirty.
Thanks for the reply!
For a brush that get clean once a year, the bristle look pretty clean.
What did you used to clean the brush with?
Do you have to soak the brush in APC, or degreaser?
The way I clean brushes: Spray them down with LATA, then scrub them on the cement driveway and rinse with the hose nozzle. Super clean brush.
Does this also leave a clean patch on the driveway. I’m asking for a friend.
Does scrubbing the bristles on cement wear down the bristles quicker?
Have you seen Ric's driveway? He must clean a few thousand of them on there. ;)
Well that clears up what he’s doing out there with his headlamp on at night
