What's the difference between the flat pads and the CCS pads (besides the obvious visual differences) with the grooves cut in them? Is there a time when you would use a flat pad in place of a CCS pad or vice versa?
Flat foam pads...I consider to be "the original" foam pads.What's the difference between the flat pads and the CCS pads (besides the obvious visual differences) with the grooves cut in them?
Ryan, if you really want to match your setup, post what pads and polishes you are using. Then we can go from there.
