Thanks Mike, I was hoping you may provide your view on the above, but obviously not (?!).
If I don't reply to a follow-up question on any thread it's almost for certain because I have not seen the follow up post.
I can't subscribe to every thread I start or every thread I post to as my e-mail in-box would fill up everyday. Besides that I'm often busy with offline projects, I try to get on the forum in the morning and a little throughout each day. If you see me as "online" it's because I'm logged in but often time working on other projects.
Now to your above question...
Back to original question, what is your opinion on the new 4" BP for 3401 regarding the pad/BP size?
What pads are recommended for this BP as 4" pads seems to risky, 5.5" pads are too big.
Thanks in advance.
My opinion is that it makes the Flex 3401 even
more versatile because now you can use the
safe power the tool offers on smaller, thinner panels without buffing on top of a raised body line or an edge.
The design of the tool, specifically the metal housing or shroud surrounding the gear drive is not in my control nor Autogeek's. It's larger than 4" so anytime you're buffing and using 4" pads you'll need to be careful and
focus on the task at hand so that you don't run the housing into a wing, or hood scoop or anything else that projects outward from the body in such a way as to pose a risk.
Luckily, there's not that many body styles or components on modern cars where this will be an issue.
Each person can decide for themselves if 4" pads on the Flex 3401 are a good option for themselves, their needs and their skill level.
As for me I use the 4" pads on the Flex 3401 all the time. In fact right now as I type this there are two Flex 3401 polishers fitted with 4" backing plates in the studio ready to go to work.
I've extensively tested the LC 5.5" Flat pads on a car yesterday. It was a yellow pad, and woow .. Flex has so much power and cutting ability with this pad. I was amazed.
There was not much room for errors as the BP was the same size as the pad, so I had to be careful (as advised by Dave), but overall the performance was excellent. BTW I've used the UC in the process.
I too like 5.5" pads on the Flex 3401. With the new Flex Adapter and Backing Plates a person can now match the pad to their comfort level and the panel they are working on.
FLEX XC3401 Changeable Backing Plate System
And the 4 3/8" Backing Plates for 5" and 5.5" pads
FLEX XC3401 Mini 4 3/8 Backing Plate
:xyxthumbs:
