Dear folks, anyone of you using the Flex 3401 with MF pads?
I have few Meguairs MF pads which I used to pair with 110V2 and I thought I can use it on 3401 to achieve something more.
However I had tried few times and I think 3401 don't really like MF pads! With MF pads, the 3401 is simply too hard to control as it will just run away if you are not flat enough! I also cannot finish out nicely with the MF pads a it always leave me some hologram. LC CC pads that comes with my package is much easier to use.
My own conclusion is, 3401 is so powerful that when used with THINNER pad like MF pads, the CUSHION of the pad is simply not enough to absorb the extra power from the 3401 and make it hard to control, just like controlling a mad cow! It might be good for spot correction though since MF pad is more aggressive than foam pad.
Hope you guys can share your experience! Cheers!
