Kamakaz1961
- Aug 23, 2013
- 4,389
FINALLY!!! I was able to use the PE-8 this morning for a considerable amount of time. I wanted to give anyone who is looking into getting one or has one my thoughts on the PE-8. I did an exfoliation of my ride this morning (could only finish the front half of my car due to time constraints). Wash, Clay, Polish (with my Flex 3401 w White Pad and SF4500) and applied a sealant with the PE-8. I will be applying a wax with it to later today/tonight for the heck of it and get used to the PE-8.
The 1st and most important to me is that speed setting 1 at 1,300 RPM is fine. I see a lot of negative comments regarding that 1,300 RPM is too high. I applied a sealant on the hood and front fenders. I had to bump the speed setting up to 2 as Speed setting 1 was TOO LOW. So any of you that are concerned with speed setting 1 at 1,300 RPM as I said before it is a NON-ISSUE (about the 4th time saying this)
I used a 4" Red LC Hydrotech Pad.
Now for the parts that will take a bit getting used to:
1. You will have to get used to keeping the polisher FLAT. It will grab and walk if you are at an incorrect angle. IMO the handle it came with is useless. Some may disagree but that is me.
2. When spreading sealant or any other compound/polish you better know how to do the 10/2 method of applying the product as I had splatter all over the hood. Once I used that method I had no issues. Mike Phillips has a how-to; to show what I am talking about.
3. I can see where the holograms can come into play. As I was applying sealant you could see how it could hologram. In my case this was not an issue as I was applying a sealant. No cutting ability at all and after removing the sealant no holograms were present.
4. Speed Setting 1 (1,300 RPM) is fine. As I said before, I had to bump the speed setting to 2 for my taste.
5. The Side Button: It took me a few tries to really get the feel of the button. It IS POSSIBLE to control the speed if you get used to it. You can adjust the speed setting pretty easy even when the PE-8 is running. My case was to bump the speed setting to 2 while it was running. IMO you will or can get used to the side button. I have and it is not a problem.
6. The PE-8 is quieter and smoother than your DA. I am used to my DA being louder and vibrating. The PE-8 does not do this.
7. GET the 5/8 extension. IMO that gives you more maneuverability with the Rotary.
8. The PE-8 is light and you can maneuver the rotary real easy.
OVERALL I am happy I got the PE-8. The biggest thing you will have to learn is how to stop the walking and grabbing, however, with a few more tries I think I will master it. As for applying sealant compound/polish I highly recommend learning the 10/2 technique so you will not splatter like I did in the beginning. I will be finishing everything tonight and in the morning (had to work so not enough time to finish).
I have my PC7424XP set up to where I can use ALL of the Flex's BP and Pads for the final polish after using the PE-8. Henceforth, no holograms period! There are adapters that can make that happen. It also applies to any other DA like the GG or Megs or Harbor Freight....
I hope this will help with people sitting on the fence or for an FYI
Have a great day everyone!!
:buffing:
:buffing:
