Nanoskin Autoscrub pads are for DA/Random orbit use only!
From Nanoskin's Website:
DIRECTIONS:
Use ONLY on clean, cool paint and out of direct sunlight. DO NOT work on the surface below 55°F and over 144°F. Please use in an inconspicuous place for the first time in case of unexpected adverse effects on paint surface.
Thoroughly wash vehicle free of dust, sand, and dirt.
Dilute GLIDE to desired strength. (16 Oz. makes 1 Gal. RTU.)
Mist sufficient GLIDE onto the surface evenly.
Polish the surface with dual action orbital polisher using light pressure (Low Speed).
Wipe off residue with clean dry microfiber towel.
NOTE: Using with 6” soft-edge DA pad is highly recommended.
Sufficient lubrication is crucial to the AUTOSCRUB application.
Plain water is NOT an adequate lubricant.
DO NOT use with rotary polisher.
AUTOSCRUB is not solvent resistant.
Remove tar & grease before application
