Flex XC3401 4" Pad Question
jmark350z
I have a Flex XC3401VRG and it works well. It is easy to use on large areas but on the cars I regularly detail there are many small areas that need a smaller pad. Should I sell my Flex and pick up a PC XP with the 5.5 & 4 inch pads or just add the PC XP to my kit? I don't think I can justify keeping both buffers as use them on my personal cars only. Thoughts?
Anyone interested in a lightly used Flex with case and pads? I bought it new from Detailed Image. It is in excellent shape. What should I sell it for if I decide to? Anyone here wanting to moveup to the Flex?
For the smaller areas, you can just do them by hand if getting an XP is out of the question. OR you can fabricate a smaller BP for the flex, i read a post about someone who has successfully cut his BP down. You might want to consider that. :)
The Flex 3401 is a great machine. If you can add an additional DA polisher to your arsenal then I suggest you do. It's a one-time purchase and you'll more than likely have them forever.
I have different size backing plates for my Porter Cable 7424 that allows me to use 6", 5 1/2", 4" and 3" diameter pads.
The backing plate on the Flex can be turned down to accommodate smaller pads but if you attempt this I suggest it be done on a lathe.
Thanks guys. I know that someone used to make an adapter plate for the Flex. I guess that is no longer made. Is the PC XP easier to handle on car vertical surfaces? I find the Flex to be a handful on the vertical surfaces. I am thinking a PC XP with 4" pads might be the ticket. If I find out the PC XP is all I really need I can get larger 5.5" pads for it and sell the Flex.
The Porter Cable is a smaller, lighter, less powerful machine. This said, it is easier on the body that the Flex.
You can sell the Flex but the question is how much of a financial hit will you take? New, the Flex is a $300 machine, used you'll probably get $200 to $225. The amount of depreciation you'll absorb will nearly pay for a Porter Cable polisher.
Ultimately it's your decision.
It's the easiest machine to use when ti comes to removing swirls and polishing to a high gloss on both vertical and horizontal panels.
I gave it a ranking of 1 in my article on polishers...
How to choose the right polisher for your detailing project
Used 4" pads quite a bit on the swoopy panels of this Porsche and whenever I could used the 5.5" pads for maximum efficiency...
1994 Porsche Detailed for "Operation Comfort" Modeled by Brittany from Stuart, Florida
The Porter Cable and similar DA Polishers can do amazing work when used with the right pads, products and technique...
^ Anyone know if/when this will be available again? Thanks.
Don't sell your Flex like everyone's saying. Buy the PC with the smaller BPs for those smaller areas. This is what I do now.
I have been intending to fabricate a lightweight 3.5 inch diameter spacer out of a dense foam rubber about 3 inches tall with velcro on either end that will allow for the use of 4 inch pads on my flex. I'll get around to it soon and will post pics of it. My vision of it is a simple thing to make, I just need to find the right piece of dense foam rubber that is light but kind of hard.
"Anyone interested in a lightly used Flex with case and pads? I bought it new from Detailed Image. It is in excellent shape. What should I sell it for if I decide to? Anyone here wanting to moveup to the Flex? "
Mike, so it's ok to advertise and sell my Flex on the Auto Geek Forum?
At one time I thought there was a forum here to allow people to sell products they no longer were using. Wasn't advertising for anyone. I have bought products from Auto Geek as well.....jeez.
