Torsion Tool
- Jun 22, 2006
- 183
If doing this for profit then speed rises as a consideration. For a DA it seems the Flex would be the better choice as it has a stronger motor and will break down polishes faster. That said, you probably will end up with at least one machine of each kind, DA & rotary. Most people use the rotary for cutting and other remediation saving the DA for LSP application. In either case practice on clean, junked panels until you are familiar with individual limitations of the machines, polishes, and pads. It just takes time and practice. Hone your technique now, up front, so that word of mouth from quality jobs keep you busy later.
