Here's a picture of the Flex 3401
"optimized" and in action. Not the backing plate and pad.
Here's the Rupes Bigfoot 21
"optimized", note the backing plate and pad.
Note in both pictures above I took them while Eric was buffing out the curved portion of the panel and
pad rotation was maintained with both tools.
As for cutting, get one of the original Purple Foamed Wool pads, the thick ones, not the thin ones as forced rotation tools like thicker pads better than thin pads, it's free spinning dual action polishers that tend to like thinner pads.
The fibers that make up a fiber pad are a type of abrasive that compliments any abrasive product you're using for maximum cut. Of course the downside is the fibers can leave their own "cut" in the paint that you'll need to polish out using foam.
If you're running into DA Haze or Micro-marring issues, sometimes it's the
abrasive technology you're using and sometimes it's the
paint.
Troubleshooting a problem
If you have
ANY other type of polishes, do some troubleshooting with the finishing polishes by using a tape-line. You can troubleshoot the origins of the problem by troubleshooting.
Here how to troubleshoot this problem, in the below example I'm using Wolfgang polishes to test with as these have known good abrasive technology.
How to troubleshoot a problem
Find a section where you see the defects and place a tape-line across it so the defects are on both sides of the tape line.
Next buff on just one side using good technique with your compound and polish like you're doing a Test Spot.
Step 1 - Place a tape-line down across the section of paint where you see the problem.
Step 2 - Take your DA Polisher, a clean foam "polishing" pad and some Wolfgang Total Swirl Remover and buff on one side of the tape-line for about 6-8 section passes. DON'T BUFF TO A DRY BUFF. YOU SHOULD ALWAYS SEE A WET FILM OF PRODUCT BEHIND THE PATH OF TRAVEL FOR THE POLISHER/PAD. Anytime you see you are buffing dry, STOP BUFFING.
Are the defects gone? If so, move to the next step.
Do the defects remain? If so post back here what you see.
That's how you can troubleshoot to see if it's the abrasive technology. The idea being to keep all factors the same except one, in the above example the polish. If there's no difference then you can keep the polishes the same and switch out pads. If it's foam pads you need to use clean pads to test with. If you find it's not product or pad, then you can test technique.
It helps of course to have a flat panel to look down on for troubleshooting. Once you find the culprit, switch your process for the car to what fixed the issue in your troubleshooting testing.
:xyxthumbs:
