Foam Cannon Adapter Help!
AlexisP
Hello,
I'm new in the Forums as well as detailing,
I have been looking for around 3-4 weeks, and i still haven't found the right adapter that i need for the Foam Cannon of AutoGeek(MTM)
My Machine is an Black & Decker PW1700 like this one: Black & Decker Latinoamérica - Lavadora a Presión PW1700
So this is the box of the machine:
And here come's the picture of the wand:
So with this picture:
At first, i tought it was the Karcher, then the Kew/Alto, Then Bosch and then Lavor.
But none of the convince me, had anyone got a PM like this or know what's the right fitting for a Black&Decker Machine(Like this)?
Thank you very Much!
Alexis
Try calling AGO Customer Service...it may be a common question for them
I did, but they are in the same position as me haha, at first they tought it was Karcher and now with the pictures they think is like Bosch.
But i want to be 100% sure because i'm taking this outside U.S :/
Thank you!
I got some bad news. You need a B & D adapter...I'm 95% sure nobody sells these alone in the USA
You need a B & D adapter:
The good news is; I can tell you where you can get one shipped from overseas for about $25.00. Rumor has it the Lavor one will work with some grinding:
You can also make your own...there's a thread on here somewhere about making one for a blue hawk or something like that. Basically use another wand from B&D and cut it. Then put a fitting in it to adapt to the foam cannon with epoxy. I have been using mine for almost a year with no problems
Sent from my XT1030 using AG Online
From where, So if i buy the MTM Foam Cannon from AutoGeek, should i order it with the Lavor Fitting?
