Foam Cannon detail Mazda
astrogus
Did a friends Mazda this morning figured i would share some pics of my foam cannon as well as the turnout of the car.
Rims: GG wheel cleaner
Wash: Foam cannon Megs hyper wash
Clay: Megs Fine
M205 white LC pad
LSP: Automagic wet wax
Tires dressed: Megs WB dressing
Looked like MY lil Mazda 3, although, that one is not a Grand Touring.
Nice job. I need to use my Foam Cannon since I've had it for a month or two. I just found out that it will not connect to my pressure washer. DWAYNE!!!!!! WHERE ARE YOU????????? lol You might have the answer to my question.
one thing I would say about a foam cannon is that it makes washing a car FUN!
Clay: Megs Fine
M205 white LC pad
Hi astrogus! How much Hyper wash and water did you use in the foam cannon bottle? I don't seem to get that much foam.
Thanks!
Syd
I fill the bottle above 3/4 full, and add about 1oz of Megs hyper wash. You gotta make sure to shake it up very good, when it starts to seem watery when it's spraying shake it somemore. Hope this helps......:dblthumb2:
I think the foam cannon is making the Christmas list. Nice write up!!
Thanks! I'm using the same method with the product, it gets a bit foamy but not like yours could it be my pressure washer? What are you using?
Im using a gas powered Honda GX 2500 PSI commercial pressure washer, has an AR pump that pumps 3.0 GPM. There a bit pricey but there worth it, nothings comes close to a Honda in pressure washers.
This is my car the first time I ever used a foam cannon.
That is just great Dwayne! What Shampoo did you use there? DP Extreme Foam? what was the shampoo to water ratio you used in the foam cannon bottle?
Feed back please
Thanks!
Thanks! :xyxthumbs:
