Foam Cannon Question
Could someone please post a pic of the nozzle of your foam cannon. I dropped mine the other day and now it's not working. I'm not sure if I broke a piece off the front.
Thanks
I presume you've played around with the inlet valve - aka, the knob on top. Turn it all the way to the left. ANy output
Unless by some weird chance you knocked some sort of sediment in any of the pickup holes, jet, etc....can't see where the low pressure output...
Take 2 steps back. Gun/ wand/nozzle on gun - output is fine >
Have you cleaned the foamer screen? It can clog with hard water or soap residue within 3-4 uses. Always run a bottle of clean water (or even better, CLR) after each use. The nozzle looks fine. I thought my nozzle was broken the first time it clogged on me.
Not an AG cannon, but appears to be same construction
My GUESS is something, likely dried soap or some other foreign material, was jarred loose and plugged up the canon. There are posts and videos on how to take the canon apart and clean it.
Thanks for the pic. I will have to take it apart and see if it's dirty. Just odd that it worked fine until I dropped it now it screwy.
Isn't there a filter that needs cleaning periodically?
The filter looked pretty good. I don't use the cannon very often, only when I mobile and want to get noticed . I put it back together and it now seems to work fine. I think when I dropped it I may have moved it inside the housing.
You cant really look at at the screen and tell its clogged. The CLR probably cleared it. Just run a bottle of clean water thru it after you are done foaming. I use it to rinse the last car I foam.
Thank you for the update. Glad the canon is back in service.
