Hammer77
- Aug 23, 2015
- 1,043
- 1
Hello all! Okay, I got a foam cannon and a small pressure washer. The cannon I got right here at AG, the washer is a Karcher K2.300. A couple weeks ago we had nice weather on a Friday here in Michigan, I used my new toys. After setting everything up, I hooked up the cannon, after a few minor adjustments. Nothing but nice thick foam was flying. I was able to foam the entire car, and still had a little over 1/4 of the bottle leftover. I keep the adjustments the same, never touched them.
Fast forward to this past Monday. My car was a mess from a wet nasty drive back to the Metro Detroit area, so after I got home from work Monday morning, spring is in the air, and I had the itch loaded up the cannon and was ready to go to town. Started with the rear section of the car. The foam was coming out nice, as I moved the rear drivers side, I noticed about 3/4 of the solution was already gone, and the sides of the bottle were collapsing.
So my questions.
1. Where do you have your flow adjustment set?
2. Where do you have your spray adjustment set?
Also, I used about 3oz of Hyperwash both times.
Any insight would be appreciated!
So my questions.
