Foam Cannon ?
What about the gun designed to connect to a compressor? I just received an excellent compressor as a gift, any comments on that one?
The ones that connect to a compressor are "foam cannons". "Foam guns" connect to a hose.:props:
Not necessarily. If it connects to an air compressor, it's one of those dry foam guns, tornadors i think. Those really arent meant to be used on the outside of a car. If it connects to a pressure washer (water) then it's probably very good. I have a foam cannon and i still love using it even after 2 years. Good Luck! :dblthumb2:
Sorry, you are correct. For some reason I read "compressor" in tanninman's post and for some reason processed it as "pressure washer". Don't know what I was thinking (must have still been waking up. Thanks for catching it!:props:
