Plan b Detail
- Jun 20, 2011
- 51
Which one works the best? I am trying to get a thick foam on the car and have access to a hose, pressure washer, and compressed air. Just wondering what yall though before I add to the cart :xyxthumbs:
How about foam cannon since you have a power washer. I have one and it works great, just need the right soap.
Agreed. It seems as if your best choice is not listed, ha. You already have the pressure washer...so that makes the foam gun redundant. The foam blaster (not quite sure what that is), but I'm guessing it's possibly a trigger? If so...screw a trigger, you'll have cramps, ha.
Then there's the Foam Tornador. Let me tell you something about the foam tornador...it's horrible. It puts out a dry foam, and a canister of product gets you about 15 seconds of continuous foam. I have one, and had trouble finding uses for it. I still haven't found any use for it besides a carpet prep tool. But even then...you're better off just using aerosol cans. So basically, it just sits there collecting dust.
Foam cannon is your answer. You'll love it, it will give you a nice thick clingy foam, AND you don't need much product to fill the canister. I use one every day, and I can typically cover about 3-4 vehicles in foam before I have to refill. Great tool. :dblthumb2:
Is the foam tornado different from what other tornado that you really liked?
I have this pressure washer... Will it work well still?
Cleanforce 1,800 psi 1.6 GPM Axial Cam Electric Heavy-Duty Pressure Washer - CF1800HD at The Home Depot
