Foam gun soap
DG 901 in foam gun without any dilution. Put about an inch of it in the foam gun. Do not add any water. Set to setting A. Bank on it. Works perfectly.
Can someone give me a recommendation on which soap to use while using a foam gun. I loaded mine with Megs ultimate soap and set the gun to its highest setting while it did ok the retention time wasn't very good. How do I get the foam to "stick" and stay on the vehicle for a good soak? I am using a Gilmour 95 foam master...
Sent from my DROID RAZR HD using Tapatalk 2
Megs Ultimate, or Gold for that matter are NOT what you want to use for maximum sticky foam effect. I have both the Gilmour gun and the HP BF cannon and found that you'll need a quality shampoo. Minimum would be something like Megs HyperWash or Shampoo Plus, or say CG Honeydew. All of those I can say will foam, (and stick) to acceptable levels. I would also not try to run any soap at 100% strength. It'll need at least a 1:1 if not all the way to 5:1 dilution to 'draw' correctly through the orifice in the gun(s).
Now that all these questions going around I want to ask as well. Just got my item foam cannon and I want to try different soaps too. I have Megs #62, DG 901 & other local store stuff. And, I want more!
I plan on making an order for some more soap like DP Xtreme & WG but wanted to pick another one. I hear a lot about Honey Dew & Maxi Suds II but what about Mr Pink?
