BobbyG
- Dec 29, 2009
- 13,211
Waiting for said pics later!
I'll take them and post them here tomorrow....
... Just to be clear, I'm guessing you are talking about the MTM Hydro or Mecline Foam Lance. They are not the same as the one AG sells. If you look at them closely, you will SE they look similar, but just aren't the same. I'm not saying one is better than the other. Just that they are not the same. Even if they did look the same, the internals are what matter, and there is no way other than to dissect them both to compare those.
I'll take them and post them here tomorrow....rops:
etc... So, they look similar at first glance, but are not the same, only if even going by external appearances. I think it would be pretty lame for AG to almost triple the price for a sticker. What I'd like to see is both of them tested against each other to see the performance difference if any.
Looking forward to see what mods you did to your foam gun.
Foam Guns
Actual cost of said modification - $4.00
Improvement in overall performance - Priceless....rops:
Foam Guns
If you look at the Wolfgang Foam Gun you'll notice that it comes with a red squeeze nozzle. This is pretty typical of what you'd find in your local garden section and it includes a quick disconnect for flexibility.
Wolfgang Stock
Initially, I was a bit disappointed with foam gun but not anything to do with the unit itself but rather the water pressure I was using. I have well water my water pressure ranges between 35psi and 55psi which works however not to my satisfaction.
I stripped the foam gun down to it's bare essentials and felt that some of the issue stems from flow restrictions within the red nozzle. I removed it and mounted a simple ball valve which allows me full pressure without restriction and the improvement was significant.
Wolfgang Modified
does anyone use one to foam seats or carpet?
Let's Compare:
MTM Hydro from Amazon
AutoGeek Foam Cannon
As you can see:
1. Bottle is different shape, AG neck is straighter /angular, MTM bottle neck is rounded.
2. Adjustment knob on top is obviously different.
3. Flange that screws on bottle is knurled on AG one, smooth metal on MTM.
4. The "beak" on the AG one has a collar, MTM does not.
Let me guess...... You put front and rear sights on your foam gun... lol.
I have also seen the foam lances sold from amazon and other sister stores. I am interested for product updates from those who have bought one of those.
They work great and I know you like to use dawn soap. Foams up really well with them.
LMAO....I just saw this and you might just be onto something!! :laughing:
So with the slight differences in bottle shape, knob size, collar etc. At the end of the day it comes down to performance. In this case $80 worth of performance difference. I have heard that, and if I'm not mistaken you can switch from foam to straight water with the AG one. I believe If I'm not mistake a forum member pointed out the difference in another foam cannon debate. Even if that's true , still wouldn't get me to on board with that. I would prefer to spend $6 on quick disconnects at lowes and swap back and forth between my lance and foam cannon. I personally don't see how the AG foam cannon could give a better spray pattern than an mtm.
