Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Foam Pad Options for the Griots G9 Polisher
I get asked a lot of questions in general and also in specific. This article will present pad options for the new Griot's Garage G9
For most of us, when using this type of tool on modern or new cars, the 5" backing plate with smaller pads is the way to go simply because the smaller pad diameter tends to fit the body panel designs of new and modern cars better than larger pads. Byt this I mean, most car hoods, fenders, doors and fenders are not simply large flat panels. Instead they have a SHAPE and the shape will include a raised body line. Besides any raised body lines you will also have the EDGES of the panel to contend with. Because it's a good practice to NOT buff on edges or body lines, smaller pads will fit modern car body panels better than larger pads. This is important with any brand of free spinning, random orbital polisher as the key to great paint correction is to maintain pad rotation. Smaller pads rotate better than larger pads when buffed curved body panels.
>>>This space reserved for pictures of body panels with raised body lines<<<
Currently, I have a good selection of Lake Country, Buff & Shine and Griot's BOSS pads in the garage that I use for our car detailing classes and projects. I've had the chance to use a lot of different pads with the new Griot's G9 and at the time I'm writing this article, I tend to like a tick thicker foam pads than the thin BOSS pads. The thin BOSS pads are great, but the G9 has so much power you don't really need to abide by the old saying, thin is in when it comes to choosing pads for the G9.
As such, I've been liking the Buff & Shine Uro-Tech pads to date and that's because their just a tick thicker than the BOSS pads, the Lake Country ThinPro pads and the Meguiar's foam discs. The B&S Uro-Tech pads are also just a few 8ths wider in diameter than the LC SDO and HDO pads. The RUPES 6" or 150mm foam pads are also a good match as are the Griot's NON-BOSS foam pads.
Here's a boat load of pictures to show you most of the 5.5 pads available at Autogeek that are a good match for this tool.
Griot's Foam pads
Because it's a Griot's tool, let's look at Griot's pads first.
Griot's 5.5" Universal Foam Pads
Griot's offers a set of 3 different foam pads in 4", 5.5" and 6.5" from Griot's. I'm only showing the 5.5" below. These pads are 15/16" thick. We can just call it an inch.
These Universal pads measure in at 5 1/2" in diameter
Griot's 5.5" BOSS Foam Pads
These are the very thing foam pads introduced originally for the BOSS long stroke polishers. They measure 9/16" thick or thin, depending upon your perspective. We can just call it a 1/2 inch.
The diameter measures 5 1/4"
Lake Country SDO, HDO and Buff and Shine Uro-Tech pads
Didn't mean to lump these two brands together and will take dedicated pictures of the two brands ASAP, but for now, at least you can see them and their widths.
From left to right
5.5" Lake Country SDO, 5.5" Lake Country HDO, 6" Buff and Shine Uro-Tech
The Lake Country 5.5" SDO measures approximately 5 3/8"
The Lake Country 5.5" HDO measures approximately 5 1/2"
The Buff and Shine 6" Uro-Tech measures 5 5/8"
RUPES 150mm or 6" foam pads
Yeah yeah yeah I know, RUPES don't like to co-mingle. :laughing: Whatever... RUPES makes great foam pads and this particular size fits the Grit's G9 really well.
The RUPES 6" pads measure in at 5 3/4" wide
RUPES Mille Pads - SUPER THIN
These pads are intended to be used with the 5mm gear-driven RUPES Mille, kind of like the FLEX 3401 only with a 5mm orbit stroke length whereas the FLEX 3401 has a 8mm orbit stroke length.
They measure in at 5 7/16ths" wide
Lake Country ThinPro 5.5" pads
Lake Country makes these exclusively for Autogeek, (I think), and these pads are great on tools like the Porter Cable, Meguiar's MT300, Harbor Freight, and the Torq 10X, etc. Basically, the 8mm to 10mm free spinning random orbital polishers.
The ThinPros measure in at 5 7/16ths inches wide
Here's all the super thin pads side by side from a horizontal point of view
The RUPES Mille is the thinnest
From left to right,
Thinpro, Griot's BOSS, RUPES Mille and Meguiar's
All of the above pads fit any 5" backing plate with a little extra velcro on the back side to help you CENTER the pads.
You also need to get one of these,
Griot's Garage G9 - 5 inch Vented Backing Plate
On Autogeek.com
Griots Garage 5.5 inch Orange Foam Correcting Pad (2-pack)
Griots Garage 5.5 inch Black Foam Finishing Pad (2-pack)
Griots Garage 5.5 inch Red Foam Waxing Pad (2-pack)
Griot's BOSS Pads
Griots Garage 5.5 inch BOSS Foam and Microfiber Pads
Buff & Shine
6 Inch Buff & Shine Uro-Tec Foam Pads
Lake Country
Lake Country HDO Foam Pads
Lake Country 5.5 inch SDO Pads
Lake Country ThinPro Foam Pad System 5.5 Inch
Lake Country 5 1/2 inch Flat Foam Pads
CCS Smart Pads™ Dual Action 5.5 Inch Foam Pads
RUPES
Rupes 150 mm (6 inch) Foam Pads
RUPES Mille Foam Pads
Griot's Foam pads
From left to right
From left to right,
On Autogeek.com
Griot's BOSS Pads
Buff & Shine
Lake Country
RUPES
