It will soften and lift dirt, but it still needs to be washed with a sponge/mitt. It can remove some of the sealant/wax if mixed at a high ratio.I heard that the reason for foaming is to lift up dirt without touching the car.
However if foam is that STRONG, wouldn't that also lift up your sealant and wax??
Foaming is an easy way to easily coat the paint with soap to help loosen dirt since foam will tend to cling to the paint. A foam cannon is even better.
The type of soap and dilution will determine whether it will strip the protection.
[SIZE=+2]I heard that the reason for foaming is to lift up dirt without touching the car.[/SIZE]
Where did you get this info from?
Flash is back!!??
How does that ankle bracelet feel?I'm on weekend release. I have to report back in @ 0400 tommorow![]()
It's all about lubricity. More the better.
Only rookies use a foam gun
I used to think the same thing Flash until following Chapman around for a week and I now have one on my wish list.
:iagree:It's all about lubricity. More the better.
