A-train
- May 17, 2011
- 1,167
If the pre soak loosens any grit, a rinse will get rid of it before you grind it into your paint with your wash mitt.
That's exactly why I rinse after I let it sit.
Being the proud owner of a foam cannon (thanks to A-Train) an using it for a week on clients cars i would have to :iagree:all depends on the soap your using. I used CGW&G to strip before a correcting an it worked perfect. but also use megs hyper wash on maintenance washes an dosent seem to affect LSP (so far). So as i see it as long as you dont use a high dilution the soap shouldnt strip LSP
It's an MTM hydro. Got it off amazon.
What soap are you using and how are you dialing the gun in?
I use chemicals guys CWG, optimum, and dura gloss. I just adjust the nozzle on the end to shoot a tighter pattern, you could also try putting in another oz of soap and not filling it all the way up. If I want it thick ill put two oz of soap and maybe 24-25 oz of water shake it up then fire away. I traded lsufan my old one, but just orders a new one bc I missed it.
