following claying
BILL
Pinnacle Advance Finishing Polish or Paintwork Cleaning Lotion :confused:
I would say cleansing lotion... That way you get off all the imperfections before you polish. But.. then again... the lotion has some filling propeties that a polish would remove... hmmm...
KILLERWHEELS TO THE RESCUE!
Im thinking cleansing lotion, then U.P.P.:confused:
If you are going to UPP (paint sealant) then the paint must be pristine for proper adherance and best durability. I would refrain from the lotion as it has fillers, and probably use the finishing polish which has light abrasives. And to be safe I would rewash or alcohol/water rub down prior to UPP.
Only other option is to use finishing polish, then paintwork lotion, skip UPP, and go straight to the carnuaba topper. Durability will not be the strong point, but I guarantee the look will be dripping wet.
Decisions, Decisions !!
Thanks killr........I do have a little thinking to do.......;)
I already have some Mothers Pre-Wax Cleaner, since i already have that, would that be a good subtitute for the advaned finishing polish??
Also is AIO an option following claying?
Clearly a very good option, both sealants (UPP) and waxes adhere to it well.
thanks........ i really meant right after claying in place of finishing polish.....
