Ford F-250 Diesel Mutilple Step Correction
Ford F250 came in this week for a complete multiple step correction and interior clean up as well as
pinstripe & metal reflectors to come off.
This is a prime example of why you need to explain to ur client that there's a possibility of paint getting removed or lifted or worse before even removing.
Process: Eraser wheel on drill first to remove pinstripe and left over double sided adhesive from reflectors. Then Foam cannon wash, wheels and tire degreased and dressed, claybar, door jams pressure washed and hand cleaned, griots fast correcting cream + griots microfiber cutting pad, finished with Rupes Uno as a finishing and topper.
Next stop is to get some of the bottom panels repainted.
Sent from my SM-G930V using Tapatalk
Come, say why was it necessary to remove decal stripe?
Ah, from back when diesels used to rattle.
Nice job. Looks much better.
Nice work!!!
Thanks man!
Came out very well!
Thanks scott! always means alot!
Client/Customer requested! I personally like the cleaner look too!
Thank you sir for the kind words!
I apologize I misread your post.
I like your work, I’m getting there
