Former Rental 2014 Impala LTZ - Restored to its former glory
KMG
I was contacted by the owner of this vehicle through facebook. He started following my posts on Autopia after noticing that I was local to him, and after purchasing this vehicle contacted me in regards to getting the exterior back into shape. Being a prior rental vehicle the exterior of the vehicle has seen quite a bit of abuse both in use and in cleaning. The vehicle had heavy swirling along with lots of RIDS (random intermittent deep scratches), along with rotary burns (holograms) from poor detailing previously done on the vehicle. We decided on a multi-step paint correction to remove a majority of the surface defects prior to coating the vehicle with Gtechniq Crystal Serum Light which will keep this vehicle protected and looking good for 3-5 years.
Before Photos
The front of the car was heavily covered in bugs and other road debris which is common this time of year.
Another before photo from the driver side of the vehicle.
The rotary burns (holograms) are visible in this picture along with the noticeable swirling on the hood.
This photo shows more of the holograms along with lots of swirling and RIDS. This area of the vehicle was in quite poor condition.
Before photo of the exhaust port with lots of carbon built up around the opening.
Another photo of bugs and other debris on the passenger side mirror.
Another before photo from the rear of the vehicle.
Before photo of the passenger front wheel.
Wash Process
After cleaning the wheels and tires the exterior of the vehicle was treated to a strong foam pre-soak prior to a 2 bucket method wash, which was then followed by a final wash with a nanoskin mit.
Correction Process
I started the correction process with a test spot on the hood. This was after the compounding step which is the first step of the correction process.
Before photo of the passenger side of the hood. You can see the rotary burns (holograms) along with heavy swirling and random scratches on the surface.
Final Product
Once the entire car was compounded and polished it was wiped down prior to applying Gtechniq Crystal Serum Light. This picture is just after the coating was applied and pulled out in the sunlight.
A quick video showing the gloss and reflective qualities of the coating.
The paint is now nice, deep and free of swirls and holograms.
Finished product
Finished product
Finished product
Finished product
Finished product
Finished product
Finished product
Thanks for looking!
Thanks for sharing. Can you tell us what you used for 2 step correction? Nice job.
This car was compounded with Griots Fast Correcting Cream and was polished with Carpro Essence. It was then coated with Gtechniq Crystal Serum Light.
You did an outstanding job my friend! looks beautiful!
Nice work.I really like the lines of that car.
Amazing transformation hard to believe it was only a two step correction.
