wytstang
- Apr 29, 2006
- 4,216
It took me a while to figure out how to do this since I'm not computer savvy. But I did figure it out, so here is the way I did it.This tweak will speed up your network to the speeds you thought you were getting. It is dependant on the network equipment that you are using, so please see the oppropriate section.
By default windows uses an auto detect feature to determine your link speed. This feature can not handle 100Mbps. to change it. Click Start and right click on "My Network Places" and select properties. On the network connections windows, right click on the adapter for your network connection and click properties. Click the configure button on the Local Area Connection Properties window. Click the advanced tab on the new window. Highlight the one on the list that relates to speed. (My one card is Speed & Duplex, where the other is Connection type, i have also seen media type, and i am sure there are others) If you can figure out which one it is, simply click each one, and look at the value box, your speed property will have the value Auto Negotiate.
Click Start
Click Control Panel
Click Network and Internet Connection
Towards the bottom again Network and Internet Connection
Double click on Local Area Connection (new window will open)
Click on Properties (New Window will open)
Click on Configure (new window will open)
Click on Advance
Click on Speed & Duplex (yours may not say it like mine so find the title that deals with speed)
To the right it has a Value box it will say Auto Negotiate. Change the Value to 100 full duplex or 100 full mode.
I checked this mode using bandwidthplace.com so with BellSouth DSL 3.0 before mode results
Speed
1.9 megabits per second
Communications 1.9 megabits per second
Storage 232.9 kilobytes per second
1MB file download 4.4 seconds
Subjective rating Great
Not bad good connection....Now for the After mode results
Speed
2.4 megabits per second
Communications 2.4 megabits per second
Storage 298.7 kilobytes per second
1MB file download 3.4 seconds
Subjective rating : Great
Now the weather here is very poor (TS Barry) so I know both of these test are off. But the was still a good improvement over the standard connection. I found this mode on TweakXP.com left hand colum labeled Tweak & Tip Categories, click on Internet & Network Tweaks, click on Speed up network file transfers on 100Mbps networks (towards the bottum) for more indepth info. Enjoy faster browsing.....Oh and if there are any computer savvy folks here who see a problem with the mode please speak up. I've had the mode since last night and have been very happy thus far.
