Freeing a frozen bolt (lawnmower blade)
I would use a six point socket with a long breaker bar if you don't have an impact. The bolts head gets rounded from debris under the deck sandblasting the edges making a six point socket a must.
Agree. Six point socket and long bar. You may consider getting a helper to hold the socket against the bolt so it does not push off.
As has been said above>>>impact wrench.
I go thru this every spring, couple 'o burps and it's loose.
Bill
