dontsleeponit
- Jun 11, 2007
- 638
Bags said:Are the imported engines usually high comp...say the honda v6 vtec's? Seafoam and lucas in the same tank or seafoam first then lucas. What about BG13?
not nesisarily, its more of a high performance engine sort of thing. High performance naturally aspirated engines are usually higher compression, and octane is even more important on forced induction high performacne engines.
Im not sure if it was talked about yet, but the octne rating is the gas's resistance to pre-ignition or detonation. It has nothing to do with making more or less power, its what will correctly run the engine.
