Same!UPS tracking shows mine will arrive tomorrow!!! WOOT!!!
That was my initial guess. Thanks!Fine polish![]()
Same!
As you can see by my post count, I'm new here and while I've learned a lot I still have a ways to go compared to most of you.
Two weeks ago I applied Mothers Brazilian Carnauba wax. I want to put the Füzion on. What's the easiest way to strip the Mothers?
Fine polish![]()
:xyxthumbs: I have some Dawn.Its only wax, why bother polishing? Just strip it with dawn or CG red citrus soap
:xyxthumbs: I have some Dawn.![]()
Thanks for the link. It's a great read.:xyxthumbs:One of the most debated topics I've ever read on AGO
http://www.autogeekonline.net/forum/auto-detailing-101/66896-lsp-stripping.html
Hey mike, i know your a fan of applying wax by machine as am i
How do you apply fuzion by machine do you take it out of the jar?
Do you get a applicator pad and put it in the pot then the machine ?
Do you apply it by applicator on the body of the car then go behind it with the machine to spread it after you primed the pad ?
How do you do it mike thanks in advance
Normally I carefully knock the entire chunk out of the jar and the CAREFULLY swipe the top of the chunk of wax across the face of the pad.
You have to be very careful you don't squeeze the wax to tightly as you'll crumple it.
Also, you have to put the wax back into the jar the same way it came out as there is a light taper to the jar and if you try to put the wax back inside upside down you'll mess it all up.
Most of the time when I include a link to a thread it's because there's more information in the thread that relates to the topic being discussed. That's how I work on a forum.
For example, if you click on the first link and scroll down you'll see this,
Step 6 - Machine waxing the paint
Here the class is going to machine apply the Wolfgang Fuzion Paste Wax to seal the paint and create that deep, wet shine everyone loves.
If you click on the second link you'll see this,
Machine Waxing - The Protection Step
After carefully wiping off all polishing residue we moved onto applying a coat of Wolfgang Fuzion by machine. Two guys will use full size DA's and two of us will be using the 3" DA's...
I used a hot air gun to heat the outside of the plastic jar so I could slide the wax out as a single chunk of wax and hold it in a clean Microfiber Glove...
Then carefully swipe it across the face of a clean, foam finishing or waxing pad...
Tommy machine waxing the rear fender...
The neater and more cost effective way to apply Fuzion by machine is to do like I show in my how-to book towards the back, and that's taking the BLADE of a PC wrench because it's large and flat like a Butter Knife and scraping some wax out of the jar and spreading it over the face of the buffing pad.
Like this,
From the what it's worth file, my how-to books are jam-packed with just about everything you need to know when it comes to exterior car detailing. Of course... you have to read them....
