I have 2 that go into a 2 plug to bulb adapter. These work with the switch
I unplugged one so you can see. I needed the bulb to 2 socket adapter, and the 2 plug to 3 plug adapter.
3 plug
Then the back 2 I have connected together via an extension cord clipped to the wall
Cord is clipped to the wall all the way to the socket
Where the black and white extension cords meet, I use it as my "switch"
Rear lights on
Rear lights off
White extension cord hangs and always stays "hot", it has 3 total outlets, so I can use it for my vacuum, buffer, halogens, or whatever at the same time.
This is the type of bulb to socket adapter you need to turn any light bulb controlled by a switch into a power source for fluorescent strips controlled by a switch:
These adapters are all 2 prong plugs, and strip lights are all 3 prongs, so you will also need some of these:
So turning all 4 strips on involves flicking a switch and connecting 1 plug.
