Generator output?
I use a kranzle 399tst and a Honda eu3000is and it works perfectly. You cannot use eco mode with the kranzle. The initial amp draw when the PW kicks on is to large and the generator cant output the power fast enough. My 399tst is 15 amps. I run a 75 gallon tank, no pump. Turn the generator on and press the trigger, instant pressure every time. It does take about 2 minutes to totally prime the first time from dry tank so just keep the trigger pulled until you have pressure. With all my other tools I can use eco mode, that includes mytee steamer, mytee 8070 lite, shop vac, pc, rupes, dewalt, ect
ok wondering if this KRANZLE (K1622) would work with the HONDA EU2000i in 6the same manner as your setup
any photos or videos (your setup)?
thinking of another portable setup (parking lot) KRANZLE K 1622 with water tank or 55 gallon drum on (pull) wagon fit easily between several cars without having to move cars around.
