Wow thanks everyone for the responses! I'll start wIth a small section using the Meg's polish. Is the white pad sufficient?
Yes, start with the white pads. I'm assuming they are flat pads? The white pads work and cut nicely with a finishing polish, or say a polish like Wolfgang Total Swirl Remover (Called TSR by us folks)
The thing is with any pad, how many of each do you have on hand? If it's just 2 or 3, then you're working borderline, and if you watched any of Mike's Vids which were linked to in your thread here, you'll understand what he says.
That over-working a pad will turn it to mush in no time. Over-heating is the usual culprit to destroying any pad.
If you're short on pads, work a couple panels, with wiping, lightly brushing and cleaning the pad on the fly.
Once it starts getting over-loaded with muck, and polishes, that's it, party's over for that pad, take it off, set it aside, and attach a fresh clean one.
Let's just for say all you have is two pads. Do half the vehicle, stop, wash and dry pads. And drying might take more than 15-20 minutes. Rush pad drying, and you'll find problems. If that's the situation you're in, no harm-foul of doing a 1/3rd, or 1/2 the truck one day, and continue on the next day.
Doing my Tahoe once, it just about took me a full exhausting run of a few hours straight just to do the roof, up and down ladders, changing pads, priming pads, wiping, what a nightmare, and I was spent after like somebody beat me up.
But I got the results I was after, perfect! And I stopped with the roof, clean up, re-group and live to fight another day.
Reserve your body, your sanity, and your resources of what you have. Rush through, cut corners, and you won't get the desired results you had hoped for. Pace yourself, take your time, and enjoy the processes, rather than abhor them.
Remember, always start and stop the DA while on the panel. Never lift off with a spinning pad, sling will add much more time to cleaning off all the slung product.
Hope some of this helps.
